Posted by Lmack on June 02, 2014 at 16:07:04 from (24.131.50.165):
In Reply to: Re: Rust in Gas Tank posted by Bohn Super C on June 02, 2014 at 06:08:17:
Use Muriatic Acid the same as is used to clean brick. Be sure you know how to dilute. Add acid to water, not water to acid. You should cut the acid with equal quantities of water and acid. Fill the tank half full of water then fill the rest with acid. You can get the acid from most building supplies. Rinse with lots of water when you finish etching the inside of the tank. If you save your acid you can use it again if you inspect the inside of the cleaned tank and find more rust that needs to be removed. The acid will also remove varnish and gasoline gels. Flash rust after the final cleanse is normal. Eastwood sells a kit and you would want to get the kit for a "large tank".
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
