Re: Carberator float hight
Posted by lee on December 26, 2000 at 09:17:16 from (198.133.22.69):
In Reply to: Carberator float hight posted by Bill Jolley on December 23, 2000 at 08:25:36:
Have you got that Cub running yet? The float should not touch the top of the carb body. Best way to measure the float height is with carb removed from tractor. With bowl removed from carb and carb in hand, invert the carb so only the weight of the float is on the needle. Make the measurement and adj as required very carefully. Flip the carb over, the float and needle should drop freely. Connect a length of plastic tube to the carb fuel inlet. You should be able to blow thru the tube with the carb upright. You should not be able to blow thru the tube with the carb inverted. With the carb in hand, turn the idle adj screw in so you know you have a small amount of throttle plate opening at the idle stop position. This is to insure you are not shutting your tractor down for lack of throttle opening at idle. Set your carb mixture screw or screws at 1 to 1.5 turns out each. You've adjusted a clean carb, verified fuel delivery, I assume you've got ignition, that cub should run!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
