Re: 1953 Cub back fire
Posted by El Toro on June 03, 2014 at 05:57:07 from (96.244.7.206):
In Reply to: 1953 Cub back fire posted by Gary McArdle on June 02, 2014 at 20:34:58:
You need to remove the sparkplug near the radiator
and bring that piston to TDC on the compression stroke.
You will need a helper crank the engine and you hold your thumb over the plug hole until you feel compression and the helper slowly keeps cranking until that piston is at TDC. You can drop a long plastic straw on top of the piston if possible and watch it rise. Then look at your rotor to see where its pointing. Should be at the No1 plug tower. If it's off remove the distributor or mag and rotate it so it's aligned
with the No1 plug tower and reinstall it. Hal
