Re: International 454 transmission
Posted by walter hardy on June 03, 2014 at 14:51:25 from (98.95.87.157):
In Reply to: Re: International 454 transmission posted by jimb2 on May 22, 2014 at 19:27:57:
Checked the pressure by removing the pressure switch and using a pressure gauge, 25 psi at idle. Clutch, pressure plate and bearing, less than 100 hrs since I replaced. I removed the inspection plate and all looks good. Drained oil in each compartment, very clean. cut filter open, also clean. The noise was from under seat, as best as I could tell. When the tractor made the noise and stopped the pto and engine never slowed down. I purchased new in 1973. Have replaced the clutch a few times, rebuilt the engine and injector pump last year.
