Re: Attn. Tractor Vet
Posted by El Toro on June 03, 2014 at 17:32:13 from (96.244.7.206):
In Reply to: Attn. Tractor Vet posted by farmhand on June 02, 2014 at 16:33:01:
Do a compression check to see if it has low compression. If compression is low you may be looking at an engine rebuild. Do a tuneup new plugs, new plug wires, points and condenser to see if that improves the engine performance. Check the valve clearance too. Hal
