Either the you have low lock up pressure or the low side anti-coast clutch disks are warped and not holding.
Does the transmission lube light come on? Does the TA operate normally in the high side> DO the brakes work as they should? Those are all indicators of the TA pressures. You will need to put a set of test gauges on the MCV to know for sure.
The low side clutch disks can become warped from slippage and over heating if the TA is pulled back to use for slowing the tractor.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
