Re: 1086 torgue question
Posted by Larry B. 1486 on June 04, 2014 at 05:53:22 from (72.105.172.144):
In Reply to: 1086 torgue question posted by Ray on June 03, 2014 at 17:21:57:
I had that happen one time and it was the linkage, cable, not pulling the valve all the way up to drop it all the way into low TA. It would pull on the low side, but not hold back going down hill. Adjusted it and it worked fine. I think I had to shorten the adjustment on the cable so when you pull the TA lever down it would pull the valve up to where it should be.
