Re: 200 STILL hard to start
Posted by used red mn on June 04, 2014 at 06:06:14 from (198.228.228.169):
In Reply to: Re: 200 STILL hard to start posted by Janicholson on June 03, 2014 at 18:32:16:
The wire Jim wants you to ground is the high voltage wire (coil spark lead) when disconnected from the center terminal of the dist cap. The purpose of disconnecting that wire is so that the engine is not firing or attempting to start. That way the starter is placing a full cranking load on the battery to give you the voltage at the coil in a sort of worst case scenario.
