Re: Farmall M boiling over
Posted by mkirsch on June 04, 2014 at 06:25:07 from (65.199.189.6):
In Reply to: Farmall M boiling over posted by P T Farmer on June 03, 2014 at 18:40:46:
That tractor should not overheat no matter how hard you work it, so you've definitely got a problem.
Could be thermostat. Could be water pump. Could be crud in the radiator. Could be crud ON the radiator. Could be a blown head gasket.
Start with the simple things first.
