Re: Farmall M boiling over
Posted by El Toro on June 04, 2014 at 08:06:33 from (96.244.7.206):
In Reply to: Farmall M boiling over posted by P T Farmer on June 03, 2014 at 18:40:46:
Touch the bottom hose lightly with your hand to see if its hot. If it's only warm you could have blocked tubes in the radiator or your water pump impeller maybe worn and not circulating enough water. Hal
