Re: M, SM, SMTA carb difference
Posted by D Slater on June 04, 2014 at 13:24:36 from (184.14.161.214):
In Reply to: M, SM, SMTA carb difference posted by hayfarmer on June 04, 2014 at 12:34:13:
SM and SMTA the same for the same fuel type. Metering on a original M carburetor was different. Hard to say what a M has in it now though. IH made 3 or 4 different parts to change the metering plus aftermarket made some for M and SM. Biggest difference in a M and SM is the choke levers are on opposite sides of the bowl.
Originally a M gas and SM gas metering nozzle had different size in part of the three holes and the tip was a different size. Lots of rebuild kits that include the metering nozzle can very on the sizes if you check all.
Main seat size, air bleed size and idle jet sizes could all be different between some carburetors other than the discharge nozzle.
