I have a komatsu D31S-16 Was working great. and it just quit pulling on right side, checked all fluids and found transmission was low, not even touching on the stick. no sign of oilleak anywhere. Filled with 30 weight and started the machine up, to find oil was pouring out of the drain holes under the rear end of the loader, and even some oil from the 1/2 threaded holes on back of rear housing. Took Belly pan off under the trans. all is dry.. Any suggestions hydrshift transmission output shaft seal ??. thanks in advance David
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
