Re: Farmall M boiling over
Posted by P T Farmer on June 04, 2014 at 19:02:10 from (173.252.12.221):
In Reply to: Farmall M boiling over posted by P T Farmer on June 03, 2014 at 18:40:46:
The fins of the rad are clean and clear and I had it filled about an inch over the top of the tubes in the rad. I'll try the touch tests and maybe flush the rad with some type of cleaner. If that doesn't work I'll go deeper. Thanks a lot for the replies.
