Re: Bars leak stop leak update
Posted by Red Mercury on June 04, 2014 at 20:49:01 from (204.112.27.204):
In Reply to: Bars leak stop leak update posted by Patrick HMD on June 04, 2014 at 15:44:16:
Here is something to think about....
I had the same problem with a W-4 and a Super W-6 after I removed the water headers. They were seeping from a couple of places around the header. I don't like to use Bar's Leak or any other stop leak products for that matter. So after some thought I decided to run them with the leaks, knowing that there is a certain amount of debris in the cooling systems of all of these old tractors even though I removed as much rust and sediment as I could when the header was off. After a couple of weeks, they both stopped leaking and have never leaked since. I suspect that once the gasket got wet and then some debris from the cooling system made it's way into the leaks all was well.
