Re: Super C no spark - changed everything twice still no spa
Posted by NNP on June 05, 2014 at 06:27:32 from (66.66.112.196):
In Reply to: Super C no spark - changed everything twice still no spark posted by mkirsch on June 01, 2014 at 18:05:24:
no answers other than what's been posted for you, but just to relate.
Had a similar problem on a external coil modded magneto
recently.
Went thru all the standard tests and known good parts swapping routine just like you.
Stone simple setup and passed ALL tests. Still no spark at the points. impossible...it HAS to spark LOL
I had a spare distributor/coil setup on the bench, so swapped the whole works and it runs fine.
I have the problem one on the bench and I WILL figure it out.
Please post your success when you find your culprit.
