Re: Bars leak stop leak update
Posted by Pete76NY on June 05, 2014 at 07:26:33 from (50.32.113.22):
In Reply to: Bars leak stop leak update posted by Patrick HMD on June 04, 2014 at 15:44:16:
I have opened up two tractors without waterpumps (thermo syphon systems) one a JD A and one an IH C that people socked the old Bahrs Leak to; found HUGE clumps of the stuff in water jackets and at all low points in cooling system, bottom line is not enough pressure to get it spread around, Since then I have never used it even on pressurized systems because I wonder how much its reducing flow in tight places like in the radiator tubes. It may be a good product, but actually fixing the problem seems better in the long run.
