Re: Super C no spark - changed everything twice still no spa
Posted by Janicholson on June 05, 2014 at 08:27:03 from (199.17.6.22):
In Reply to: Re: Super C no spark - changed everything twice still no spa posted by Hendrik on June 05, 2014 at 01:08:28:
With battery on the floor, a wire from the positive post to the positive coil terminal, and a wire from the negative coil post to a condenser lead. A wire connecting the condenser body to the negative post of the battery. And a coil (high voltage wire coming out of the coil tower, and set 1/4 inch away from either battery post will spark if the lead from the condenser (attached to the wire from the neg coil terminal) is scratched on the negative battery post.
Do not do this on a battery with vents it could go boom. But that is the answer. Jim
