Re: MD injector pump
Posted by pete 23 on June 05, 2014 at 10:00:38 from (74.33.89.136):
In Reply to: MD injector pump posted by IH3688 on June 04, 2014 at 20:34:09:
Watch the pressure on pump gauge. If it drops off or is very low that is your problem. Not getting enough from tank. Some times the tank baffle comes off and blocks flow. When that happens you often see small bubbles coming into glass water trap due to the pump sucking hard but not getting fuel so air enters around gasket or bleeder. Plugged return line could be a problem also.
