Re: Bars leak stop leak update
Posted by pete 23 on June 05, 2014 at 10:06:22 from (74.33.89.136):
In Reply to: Bars leak stop leak update posted by Patrick HMD on June 04, 2014 at 15:44:16:
Many time, permatex will seal the gasket after a couple of warm up and cool down periods. Have seen that many times of those rusted up thermostat and water headers where you cannot get a perfect sealing surface. Far as block sealer etc. I rebuilt a 3020 Deere diesel some years back. It had been leaking around liner O-rings for quite some time. They had poured so much block sealer in there the block was almost full to the top. Still leaked.
