Re: 1066 Alternator Replacement
Posted by Bill in IL on June 05, 2014 at 12:45:58 from (132.3.49.80):
In Reply to: 1066 Alternator Replacement posted by 1130Leo on June 05, 2014 at 11:55:41:
Do you possibly have an early 1066 that may also have an externally regulated delco 10DN alternator. They had a 4th wire that was just a ground.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
