Re: Best Fast Hitch Conversion Setup
Posted by DeltaRed on June 05, 2014 at 17:24:10 from (65.100.146.82):
In Reply to: Best Fast Hitch Conversion Setup posted by Formerly PaMike on June 05, 2014 at 11:10:28:
You're hooking up 'wrong.Its easy.As easy as a telescopic 3point arm.Install prongs into sockets.Back up around 10" from implement.Pull out prong from socket,slide the ball onto the pin. Back up to 'set' the catches.You may need to try it a few times at first to get the right space.Too close,the prong wont spread enough to hook.Too far,the prong comes out before it gets hooked.
