Re: hydrolic leak on lo boy cub
Posted by john *.?-!.* cub owner on June 05, 2014 at 20:31:25 from (174.125.0.179):
In Reply to: hydrolic leak on lo boy cub posted by TEXAN Connection on June 05, 2014 at 18:42:03:
There is no opening in the torque tube to allow the touch control fluid into that housing even if the TC unit is leaking. Your fluid is coming from the transmission input shaft seal. Yes, it must be split right at the front of the transmission to fix it. If you are losing fluid out of the TC, check your engine oil, it is probably going past the seal in the pump mounted on the left side of the engine. In other words, you may have 2 separate problems.
Forgot to mention, the transmission probably is overfilled due to water/condensation in it. Only supposed to have 3 1/2 pints of oil, but I have drained well over a gallon of oil water mix out of them at times.
This post was edited by john *.?-!.* cub owner at 21:02:34 06/05/14.
