For hydraulic oil to be getting in the "torque tube" (that section between the engine and transmission), the hydraulic pump has to be leaking into the engine, and the rear main seal has to be leaking like a sieve.
It's time for some detective work to see what's going on:
How do you know it's hydraulic oil? Are you refilling the touch control constantly?
What seal did you replace? The rear main seal on the engine? Did you use the stock seal in the stock retainer?
The stock seal fits too loose in the stock retainer, and will leak like a sieve. So if you've got a leaky hydraulic pump too, the oil will do an "end around" through the engine and end up in the torque tube.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
