Re: 300U hydraulic very hot ??
Posted by mkirsch on June 06, 2014 at 05:25:36 from (65.199.189.6):
In Reply to: 300U hydraulic very hot ?? posted by 300dave on June 05, 2014 at 09:06:10:
Avoid running the tractor, except to troubleshoot, at this point. Speaking from experience here. If you keep running it like it is, something is going to give. On mine, it was the o-rings between the pump and lines.
Sticking out the front of the hydraulic valves are shafts with two flat sides. That is your single-double acting selector. Turn it 90 degrees one way, single acting. Turn it 90 degrees the other way, double acting. Put it somewhere in the middle or past either "sweet spot", and you have problems.
There's supposed to be a pin or some other notch that lets you know it's in the right place, but it could have been ram-rodded at some point in the past.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
