Re: Super A Hyd. Pump Seal
Posted by Dalex on June 06, 2014 at 10:23:08 from (71.108.56.18):
In Reply to: Super A Hyd. Pump Seal posted by Dalex on June 02, 2014 at 10:13:58:
Ok guys ,The seal # for the Thompson pump is Timken 470954 or SKF 7443. Not an automotive seal , I got it @ a Bearings and Drives industrial supply. Only $3.25 ! Thanks to all for your info....
