Re: Farmall F-12 Transmission Fluid
Posted by Dave Allgire on June 06, 2014 at 14:57:50 from (97.91.245.36):
In Reply to: Farmall F-12 Transmission Fluid posted by FarmallCT on June 06, 2014 at 09:47:48:
I've got 3 F-12's and 2 F-14's. I use SAE 85-140 gear lube in all of them. The book says 16 quarts for the transmission. The power lift takes about a gallon. The Heisler overdrive takes about one pint. I use the same lube in the overdrive and hydraulic lift with no problems. HTH.
