Re: 1938 Farmall F-20 Engine
Posted by Tom Fleming on June 06, 2014 at 16:02:55 from (67.20.239.72):
In Reply to: 1938 Farmall F-20 Engine posted by Dylan Barker on June 06, 2014 at 15:57:30:
ok, the O rings are at the bottom of the sleeves, between the sleeves and the block. The only way to see them is to remove the sleeves. The are in the very bottom of the sleeve opening, inset into the block.
once the sleeves are out, mic them to make sure they are not worn out or egg shape. If they are good, cut the ridge and hone them. New rings. New O rings. You will basically have a new tractor. Oh, also, make sure you do a valve job on it with new guides ( unless the guides aren't too worn).
