On the left side of the engine there is a hole with a cast iron elbow that bolts to the side of the block, a rubber hose goes from the elbow to the bottom of the radiator. If the radiator is still mounted and connected to the engine, just fill it with water until there is a few inches in the engine, check for leaks and then just remove the drain plug from the bottom of the radiator and the water will drain out. If you have already removed the radiator, then plug the hole on the left side by bolting a piece of flat steel over the hole with a gasket. Then fill with water and check for leaks. Remove the steel plate and the water will drain out.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
