Posted by Steve Wilkens on June 07, 2014 at 14:07:17 from (98.209.198.9):
Helping a friend out with his BN. It wouldn"t run, or even act like it wanted to start. So I began with the basics, flushed the fuel system, took carb apart and thoroughly cleaned it, new points, condenser, cap, wires, rotor, plugs, and since the coil seemed weak added a new coil. She fired right up. Then it wouldn"t go into gear, adjusted the clutch..it was way out. Then took it for a drive, rear axles whine a lot! Thinking it might be the bearing, tractor has been sitting for a long time, but I can"t find new bearings, are they hard to come by? It only really does it in 4th gear when moving fast, is this normal? He wants to take his wife on tractor rides, so 4th gear will probably be used a lot. She has had severe health issues over the past year and I want this fixed right for them...any suggestions??
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
