Re: stuck sleeves
Posted by toymaker27 on June 08, 2014 at 07:57:14 from (75.156.113.7):
In Reply to: stuck sleeves posted by WV Farmall on June 07, 2014 at 16:57:07:
had the same issue, had to get a higher grade threaded rod, think it was 80 grade I used
