Re: Pulling installing dry sleaves Farmall IH 400
Posted by Nebraska Kirk on June 08, 2014 at 15:56:16 from (207.91.4.159):
In Reply to: Pulling installing dry sleaves Farmall IH 400 posted by husker44a on June 08, 2014 at 15:45:15:
I made a jig that fits over some of the head studs and uses a small bottle jack to press dry sleeves into place. Another option is to stick the sleeves in the freezer over night and often they will drop into place then. You really should replace the rod bushing too since you are going to all this work. The rod bushings have to be installed and then honed to fit the piston pins before installing the pistons.
