You don't need anything that fancy unless they have been welded in by rust, meaning the head has been removed and years of water has rusted them in.
An old geezer taught me to use a block of wood, preferably made from oak, but I have been know to use pine and it works ok. Remove the piston out the bottom of the engine, and using this block of wood against the bottom of the sleeve, tap on the wood block with a small sledge. The sleeve just has to move about 3/8 of an inch on the top and it will come free; about an inch on the bottom and the same will be true. Wet sleeves mean that they are relieved in the middle of the outside diameter of the sleeve and once they are moved past the part that touches the block, they will slide right out. Dry sleeves are a bugger as the whole outside diameter contacts the block.
Make sure you replace the O-rings in the block; if not you will most likely be taking the engine apart to replace them anyways as water will leak into the oil pan. Never had one not leak when I cut corners.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
