Re: Farmall A front axle removal
Posted by JRSutton on June 09, 2014 at 12:17:46 from (71.174.108.245):
In Reply to: Farmall A front axle removal posted by jmoody on June 08, 2014 at 18:30:47:
As John said, you have to fully remove the two bolts that run perpendicular to the pin.
On top of that, the pin may be in there very tightly (hence the hammer marks you see).
To push it out - use a narrow pointed punch to drive it with a hammer - that way you're only distorting the center of the pin - not mushrooming the whole end of it.
Trust me - the more you mushroom the end, the more impossible it will be to drive out. I learned the hard way.
I had put an old socket and extension (hey, it was available...) on the pin, and tried hitting it out with that. Bad mistake. It moved a little at first, but just got stuck tighter and tighter as the pin distorted.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
