Re: 1938 Farmall F-20 Cylinders Removal
Posted by robgIN on June 09, 2014 at 18:16:04 from (76.208.3.234):
In Reply to: 1938 Farmall F-20 Cylinders Removal posted by Dylan Barker on June 08, 2014 at 09:12:13:
all of them I have pulled out have come HARD, and all you are gonna do with a wood block is make toothpicks. I have a puller and usually have to give them an assist with a sledge hammer or air hammer from the bottom because the puller on its own just doesn't have enough umph to break them loose. Nebraska Kirk has the best setup I have seen , wish I had that. You will usually find at least a couple inches of crud cementing them in at the bottom of the block. Where are you located, maybe someone on here is close by that has a puller.
