Re: Cub Lo-Boy 154 shifter
Posted by mkirsch on June 10, 2014 at 04:43:25 from (65.199.189.6):
In Reply to: Cub Lo-Boy 154 shifter posted by GT65 on June 09, 2014 at 16:34:30:
If the rails or forks were out of alignment, the tractor would not move PERIOD.
Have you tried it? What does it feel like?
The Lo-Boy 154 has the same basic transmission as a Farmall Cub, so the shifter cover comes off with 8 or 10 bolts, and you can see right down inside. The hardest part is getting the sheet metal off to get at it on a 154.
I doubt it needs a whole transmission, but without knowing more about what the tractor is/isn't doing when you try to shift into 2nd or 3rd, the best anyone can do is tell you to take it apart, see what's wrong, and fix it.
