Re: farmall C after overhaul expectations
Posted by mkirsch on June 10, 2014 at 04:55:38 from (65.199.189.6):
In Reply to: farmall C after overhaul expectations posted by PretendFarmer on June 09, 2014 at 20:05:15:
Even after you swap all those parts on to the C, you still have a tired bottom end. I don't think you'll see much if any additional power.
The problem with swapping entire engines is the C will go way too fast and the 140 will be slow as a dog due to engine RPM.
140's get more power by spinning the engine faster and running different gearing to end up with the same ground speed. If you put a 140 engine into a C, which is geared for an engine running much slower, you will not realize any additional pulling power.
Your best bet for more power would be to overhaul the C's engine.
