Re: Tractor show and mag problem
Posted by AlanA on June 10, 2014 at 08:55:25 from (108.71.121.20):
In Reply to: Tractor show and mag problem posted by HenryO on June 10, 2014 at 06:57:08:
UNPLUG COIL WIRE FROM DIST. CAP. Don't want it to fire while you do this.
Timing mark on pulley should line up just as #1 Cyl is at top of compression stroke. (remove spark plug and put your thumb over the hole to find compression stroke).
Loosen bolts holding mag, and turn the top of it toward block.
Turn engine with crank until timing mark is again at TDC. Rotate mag away from engine block until impulse coupling clicks, then tighten the bolts in that spot.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
