Re: What would cause old tractor to loose power when worked hard
Posted by Bill in IL on June 10, 2014 at 13:27:39 from (132.3.49.81):
In Reply to: What would cause old tractor to loose power when worked hard posted by luke0927 on June 10, 2014 at 10:44:26:
Another simple suspect to check out is the gas tank vent working properly. If not it will slow the flow of fuel to the carb as a vacum is created inside the tank. Its easy to check by loosening the tank cap when it starts acting up.
