Re: What would cause old tractor to loose power when worked hard
Posted by El Toro on June 10, 2014 at 13:48:50 from (96.244.7.206):
In Reply to: What would cause old tractor to loose power when worked hard posted by luke0927 on June 10, 2014 at 10:44:26:
When it loses power check the fire to your spark plugs asap before the engine cools. Hal
