Re: What would cause old tractor to loose power when worked
Posted by Mike Van on June 11, 2014 at 03:01:33 from (24.151.25.186):
In Reply to: What would cause old tractor to loose power when worked hard posted by luke0927 on June 10, 2014 at 10:44:26:
If you've been through all the easy stuff, plugs, points, fuel flow, etc, you can try a coil too, not a big money item. I'd pull the valve cover and check the adjustment on the valves, maybe do a comp. check cold/hot too.
