Re: Cub Weights
Posted by mkirsch on June 11, 2014 at 04:36:50 from (65.199.189.6):
In Reply to: Cub Weights posted by Dave Sherburne NY on June 11, 2014 at 04:32:56:
If you can't get at least 3 sets of Cub weights, both front and back, in your van, you have a very small van.
Rears are about 150lbs each and approximately 18" in diameter. Fronts are about 10" in diameter and weigh about 25lbs.
