No, it is not difficult. You just have to keep track of where the two small wires are connected, and connect the new coil up EXACTLY the same, unless it is connected wrong now.
Before you go swapping coils: Is there a ballast resistor in the wire from the ignition switch to the coil? It is a white ceramic block about the size of your thumb.
If there is no ballast resistor, you have found your problem. The coil is overheating because it is receiving 12V instead of the 6V it is designed for.
If there is no ballast resistor now, make sure you get a new coil that says, "No ballast resistor required."
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
