Re: is sa gas or kerosene
Posted by athol carr on June 11, 2014 at 14:38:31 from (122.57.233.64):
In Reply to: is sa gas or kerosene posted by rray on June 11, 2014 at 06:57:13:
There is a difference in the SA engine for gasoline, kerosene and distillate, it is in the pistons. The gasoline engine needing higher compression has a piston where the wrist pin is set lower in the piston body, the swept volume is the same but the piston top is higher up in the bore so with the same head the final compression ratio is higher. There were 3 basic sets of pistons, gasoline with compression ratio about 5.9 to 1, distillate with a compression ratio about 4.7 to 1 and kerosene with a compression ratio of 4.4 to 1.
The distillate/kerosene engines had a hop manifold with a flap valve to control heat input and they had carburetors with a drain tap on the bowl, if it stopped on kerosene you had to get rid of it out of the carburetor before trying to re-start on gasoline. The jets and venturi in the carburetor were also different. These tractors also had a separate started gasoline tank attached to the right-hand side of the cylinder head, radiator shutters, water temperature gauge and a head shield to fit over the manifold to stop the air from the fan cooling down the manifold
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
