Re: Carb does not fit back on
Posted by Robert Almstrom on December 27, 2000 at 05:26:50 from (209.90.238.56):
In Reply to: Carb does not fit back on posted by RobertN on December 26, 2000 at 20:56:30:
Hi Robert: Sounds like you have a carburetor that goes to another tractor? The reason that you had the two different size bolts was so the person could place that carburetor onto that manifold. I would see if someone would swap it out for you. Mine has threaded holes in the carburetor that accomadates the bolts that go through the manifold and I don't need nuts. Bob
Post A Followup
: Re: Re: Carb does not fit back on
