Re: amps draw for 6 Volt starter
Posted by Owen Aaland on June 12, 2014 at 16:15:22 from (216.47.33.5):
In Reply to: amps draw for 6 Volt starter posted by wm. Ecccles - Jardine on June 12, 2014 at 15:23:37:
Need the starter number to get the exact specs. Here are a couple examples.
Starter number 1107093, Spec number 2394
5.6 volts, 50 amps min, 70 amps max, 5500 rpm min.
Starter number 110096, spec number 3520
5.7 volts, 90 amps min, 125 amps max, 4500 rpm min, 6400 rpm max.
This post was edited by Owen Aaland at 16:16:34 06/12/14.
