Re: Hour meter hook-up on magneto M
Posted by Dave S. on June 12, 2014 at 21:09:46 from (208.92.170.202):
In Reply to: Hour meter hook-up on magneto M posted by Buck Clayton on June 12, 2014 at 17:44:48:
I have a H & M farmall and a B John Deere with electric hour meters. B has mag, farmalls have distributors and all three meters run off of oil pressure switches. If for some reason the ignition switch is left on while engine is not running the meter doesn't run either.
