Re: 300 Farmall Crankcase Level Rising
Posted by dej(Jed) on June 13, 2014 at 04:56:10 from (141.189.113.1):
In Reply to: 300 Farmall Crankcase Level Rising posted by Brian Schmidt on June 12, 2014 at 20:37:04:
If you are making oil, it has to be water or hydraulic oil. Ifyour hydraulic level is going down then you have a pump issue.
