Re: amps draw for 6 Volt starter
Posted by Owen Aaland on June 13, 2014 at 07:39:53 from (216.47.33.5):
In Reply to: amps draw for 6 Volt starter posted by wm. Ecccles - Jardine on June 12, 2014 at 15:23:37:
The specs for amperage draw is a no load spec used for testing the starter. The loaded draw will be much higher. Some starter specs give an amperage draw for a locked starter but the Delco Remy chart did not have that information for the starter numbers I looked at.
This post was edited by Owen Aaland at 07:41:34 06/13/14.
