Engine serial number on 460?
Posted by Hugh McKinney on June 13, 2014 at 08:13:23 from (72.161.80.24):
My 460 LP has a missing serial number plate, which should be on the right side near the clutch bellhousing. No luck there. But on the other side of the tractor, on the engine block, roughly directly below the #4 cylinder, near the oil pan rail, is a six-digit number that appears to be stamped into the casting (not cast in). Anybody have any similar experiences by which I might compare the number on theirs to try to ascertain roughly when this tractor was built? Thanks in advance, Hugh P.S.: the number is 222232.
