Re: farmall 400 drawbar
Posted by 56 Fan 400 on June 13, 2014 at 08:27:53 from (75.220.114.249):
In Reply to: farmall 400 drawbar posted by D Slater on May 24, 2014 at 08:20:20:
This hitch is what I had a problem with a while back. I also had to drill a hole in the left shaft out of the pivot ball joint. Otherwise it may slip off as the centerpoint under the engine is free to move forward and backward. I drilled a hole and put a pin in the shaft. Me and my dad replaced the pivot ball joint.
